Hi I have just bought one year subscription of recuva Professional but after data recovery not even a single file of video is playing nor opening recovered photos. Why?
Because no program guarantees 100% recovery, all sorts of things could have happened to the data, recuva does it’s best to tell you if the data locations are CURRENTLY overwritten with its red, yellow, green system but it is neither infallible nor does it know that the location did have a different file there at some point after deletion. Drive defragmentting, turning off and (later) on your computer (or drive), temporary files, anti-virus scanning and more may make a file irretrievable. Iirc windows works on last empty first use idea.
If this is an SSD recuva was made (and updated for) HDD (from before SSD drive were used as primary) and SSDs handle deletion differently.
Hi @wabangash
From your post it seems that you have recovered some image and video files but they won’t open?
That means that the recovered filled are corrupt or incomplete, that could be for various reasons as Nergal points out above.
The first thing to do is to look at the size of the recovered files and ask yourself if they are as big as you expect?
If they are only small, say 1 or 2 KB, then what you have recovered is just the files entry from the Master File Table, and not the files themselves (in which case the actual files are probably no longer there).
If however they are the sizes you would expect for image files and video files then read on.
You can try the following fixes, no guarantees of course, but other users have found them to work for some unopenable recovered files.
For the photos try opening them using Irfanview, it can often open “slightly damaged” files that other viewers will just not open.
If you can get them open with Irfanview then saving them from Irfanview “fixes” them so that the other viewers will then be able to open them.
(I’ve done that myself in the past with recovered photos that other viewers wouldn’t open.
Some of them were only half an image with the other half grey or pixilated where the original data had been overwritten - but Irfanview was still able to open and display them).
Irfanview is free: https://www.irfanview.com/
I suggest that you download the Plugins as well as the main programme.
For the videos VLC Media Player may be able to repair them.
See this YT video for instructions: https://www.youtube.com/watch?v=5x7wCHKGhpY
Here’s another which is a bit more wordy: https://www.youtube.com/watch?v=qRu0lmaUwFM
VLC is also free: https://www.videolan.org/
If that doesn’t work then there are websites that offer to try and repair damaged video files, some for free, some for a price.
(Do a web search for - video file repair).
