Recuva Pro, on USB
See quote at end then read my question : I don't use Bart PE, i want a bootable USB that will boot the PC alone, no OS.
	 I would like to use my Recuva Pro and how will it recognize the licence if I put the installation files on a usb drive ?
	Does that work? This way it will recover files booting recuva pro on an external USB drive ,
	then I have 1 external hard drive to which the restored files are saved,
	I search files that are lost from a computer's 3 hard drives, I'd recover data 1 HDD at a time, one after the other, but always saving recovered data on the external HDD.
	2SSDs, 1 PATA hard drives are on the computer.
	Could this be done. Haven't found an answer yet confirming recuvaPro licensee can use it as DOS to get on a computer without booting its windows. The Recuva PRO software should be on a USB key to do so I don't wanna boot the computer to lose data from the system file created as cache on boot.
	&lt;&lt;There's no need to incorporate Recuva into BartPE just store the files on a flash drive,
	boot BartPE with the Flash drive already inserted and it should be ready to access.&gt;&gt;
