I just recently did a recovery session myself. The program was working at about 1% every 10 minutes, but then appeared to hang at 10% for about 2-3 hours. I continued to let it run through the night and when I checked it this morning, it was done.
The reason for the hang mostly depends on how large the drive is that you will be scanning. The larger the drive, the larger the hang. This is because of how Recuva works. It scans the ENTIRE drive for files (instead of looking at the file map which is how most programs find drive information). The hang is caused when Recuva is scanning a portion of the Hard Disk with no information on it at all. If it is a fairly large sized disk, it can take quite some time to look through all of the clusters for files whether they exists or not.
Thanks
yes i left it over night and it was 25% when i went to bed and 25% when i woke up!
i'll give it another go though.
also, could you tell me what's with the ignoring of files found during the initial 'non deep' scan? are they too far gone to recover?
(i have used recuva on another drive on another pc and it's found some stuff that had been deleted so i've found it useful regardless and will be recommending it to friends and colleagues. cheers)
