Recuva drawing errors
I just downloaded the latest version of Recuva, as for the problem I think the photo speaks for itself.
(edit: see images below)
If I hold and drag the scroll bar with the mouse it draws the lines correctly but not if you click on the scroll bar instead.
Richard S.
I don't know if it's only me, but at the moment I can't load your image Richard.
It loads okay for me.
Hi Dennis I'm using photobucket, perhaps it's blocked/network routing problem or something it's still working as far as I can tell.
Richard S.
(removed by author for less bandwidth, images same as illustrated below)
New version of Recuva, drawing bug still not fixed.
Richard S.
Still not fixed.
Richard S.
Still not fixed in Recuva v.139.509.
Also it says I have 1.2GB RAM this should be 1.25GB - is this another rounding error like Speccy??
Richard S.
Can you turn off Smooth Scroll and see if this fixes this issue?
Hi MrRon, as far as I'm aware Recuva doesn't has "Smooth Scroll" so I assume you mean Internet Explorer?? in any case enabled or disabled this has no effect.
When accessing the scrollbar by clicking and dragging the offset pointer the lines separating the filenames are correctly spaced out.
However if I click line up / down via the squares at either end of the scrollbar the display is messed up as shown in the photo.
When I click down one line at a time Recuva prints lines going through text, if I click up Recuva doesn't print any lines at all.
I've not changed my system fonts or DPI settings so this one is a bit of a mystery to me.
Richard S.
Just tried that, and I get the same thing.
XP SP3: If I use the mouse or the arrow keys to scroll through list it's OK, but the effect manifests itself as soon as I use the vertical scroll arrows.
Scrolling down with them gives the effect in Richards screenshot. Scrolling up does the opposite. It creates gaps.
I also have smooth scrolling disabled in Internet Options.
