Recuva Does Not Launch
I have tried both the portable and the installable versions of Recuva, but all I get is it running in the Task Manager, but never launching on screen.
I am running Win7 64-bit with 8 GB of RAM.
Both versions do exactly the same thing - they show up in the Task Manager, but never launch.
I have to manually end the Recuva task in the Task Manager.
Is there a fix for this?
What security software do you run?
If you boot into safe mode does recuva run then?
