I have pointed out this problem earlier, but in the latest build the problem still remains:
If I put an entry into winapp2.ini like:
"FileKey1=E:\Temp|foo.bar|RECURSE"
or "FileKey1=E:\Temp|foo.*|RECURSE"
any foo.bar file in a subfolder will not be found and cleaned (say E:\Temp\mystuff\foo.bar).
However
"FileKey1=E:\Temp|*.bar|RECURSE"
does find the file in subfolders. So RECURSE works only, if the filename is a wildcard???
Moreover
will clean any subfolder called "foo" entirely.
Is this behavior intended or is it a bug?
Thanx for listening,
Mike
