There are 6 issues that seem to be uninstalled but the same recurring issues become an issue every time the Registry Cleaner is used. How should this problem be solved?
Can you screenshot (or list with full pathname) what Registry Cleaner is finding?
That will let us see if they are a concern or not.
What Windows version and build are you running?
(Is it an insider build?).
There is currently one know entry that always comes back:
‘LocalServer32\C:\Windows\SysWOW\Speech_OneCore\Common\SpeechRuntime.exe’
That is needed by Windows and so will always be recreated if you delete it.
You can right-click on it and "Add to exclude list" if you don't want to see it again.
There may be others depending upon your Windows version/build.
As the Windows 10 Spring Update (20H1) is almost here then Windows will be adding things to your registry and elsewhere in preparation for that update.
PS. We don't recommend regular use of the Registry Cleaner with Windows 10.
Registry cleaning is not needed unless you have a specific problem, it's an avdanced tool.
Unlike older Windows versions the Windows 10 registry updates/changes frequently.
