We're getting somewhere Rob as that is much better than I got with my corrupt Cruzer as both sections were corrupt and unreadable.
To answer your question, an Image file (or any file for that matter) usually takes on the appearance (icon) of the program set as default to either open it or burn it or whatever.
My Image files look like this since I installed ImgBurn a long time ago and allowed it to make itself the default program for handling Image files, as this is ImgBurns icon...
If I change the default program to WinRAR for example they look like my WinRAR icon (a personalised one by the way) ...
Yours will be the generic windows file icon as you probably don't have any program set as default to handle Images, but I wouldn't worry about that as I don't think it has any relevance to what we're doing. If you want to set a program as default to handle Images I'll show you how if you remind when we're done here. ![:)]()
If we go back through this thread Rob, every action you've done with Recuva, or been asked to do with TestDisk, MiniTools Partition Wizard, and the program in that pm I sent you, was doomed to failure before it started because of one simple thing that didn't register with me at the time.
That one simple thing was in a post made before I confirmed you had a U3 installation, and before I started experimenting with my own Cruzer.
Post number 6:
After Analyze was finished I received the following information
Drive G: - 100 MB / 95 MiB - CHS 23 64 32
Partition Start End Size in sectors
Drive G: I later discovered after reinstalling U3 to my own Cruzer, is the CDRom section of the drive, has iron clad write protection, and is recognized by windows as a CDRom (read only memory). You couldn't persuade Windows to write to that drive using any software available.
Anyways, that's by the by now, and I'm simply pointing this out for others who may find themselves down the same road.
Your drive ... Yes, definitely format it, and then that section of the drive should just open like a standard flash drive. When and if you confirm that, we'll set about getting rid of the corrupt U3 installation.
Fingers crossed the format is straightforward, but if not I've a plan B. ![:)]()
EDIT:
7-zip is not extracting anything from the drive
Do you mean your flash drive Rob, or are you failing to extract files from the Image file, which is where you should be trying to extract them. Just checking. ![:)]()
EDIT 2:
Rob, after having a re-read, I realise that I did use the word "drive" instead of "Image" in post # 33.
So ... get stuck into 7-Zip Rob and see if you can extract the files from that drive, but extract into a new folder otherwise they could be all over the place.
Slip of the pen, apologies for that. Have a try with 7-Zip on the Image file.
