Recently Used Programs and Files lists
I installed the most recent update of CCleaner and didn't release it had reset to the defaults, which included cleaning of the most recently used programs and files lists.
Since then, no programs or files are ever listed in the respective lists. In the Start menu, there's not even a blue line indicating separation from the pinned programs.
I have done a search of the problem and have tried many settings, none work. Any suggestions?
-Scott
I have the same problem with the start menu.
After using the cleaning function of CCleaner, in the start menu the recently used programs were all deleted.
I have tried pinning the programmes back to the start menu but there is always still a big space at the bottom underneath the pinned icons.
The more files I ad the bigger the blank space becomes.
I found a discussion which seems to be related to the same problem, but dating one year back:
http://forums.techguy.org/windows-vista/55...nu-problem.html
It contains a link to a software undoing changes in the Start Menu, unfortuantely I didn't get it doing the job on my computer.
Since the problem apparently doesn't appear for the first time I hope there's a fix that can be provided
by the Piriforum team.
Regards
Till
Regards
Till
Hello sorriso,
Turn off all Advanced cleaning options.Your list will start to fill back in. Cleaner > Windows tab > Advanced list at bottom.
Use the Guide . http://www.ccleanerbeginnersguide.com/
P.S. See the following post also.
:) davey
-Scott
Hi Scott,
See post above.
You may have to reboot but list will come back as you use the programs.
This was caused by turning on User Assist History in Advanced cleaning options.
These are needed rarely.
Recent Documents is in Windows Explorer list and I use it when needed.
http://www.ccleanerbeginnersguide.com/ CCleaner Beginner's Guide
:) davey
P.S. See this link at the bottom. It tells you how to save your settings. http://forum.piriform.com/index.php?showto...amp;entry104255
Thank you.
Thanks for your advice Scott!
But still have a graphic problem with the starting menu,
it is much longer then before - see attached screenshot.
Do you know how to fix that?
Regards
Till
Can you just reduce the size of the window? Make sure that Window Size/Location Cache is unticked in CC Advanced so that window sizing is kept.
