CCleaner does not clean Real Audio temp files.
C:\Documents and Settings\...\Application Data\Real\RealPlayer\Temp
(Normal delete works fine)
Win XP
CCleaner vers. 2.01.507 (also prev. latest vers. sam error)
Win XP
This will allow it to be cleaned:
FileKey10=%appdata%\Real\RealPlayer\Temp|.
- In Notepad open: C:\Program Files\CCleaner\winapp.ini
- Search for: Real Player
- Scroll to the end of the Real Player cleaning routine
- Input the following at the end of the Real Player cleaning routine:
FileKey10=%appdata%\Real\RealPlayer\Temp|*.*
Thanks Andavari! :-)
Is there more tmp files that CCleaner misses to delete?
/Bengt
Finland
Thanks Andavari! :-)Is there more tmp files that CCleaner misses to delete?
/Bengt
Finland
You'd have to report any other app you find that more could be cleaned. There's also the user created winapp2.ini that's an add-on cleaner with a bunch more cleaning routines:
