Reached maximum number of character
First : thanks for your work and your software that are a great help!
I'm trying to recover 108649 files with Recuva (900Gb). When clicking "Recover" I select the destination and I get
Reached maximum number of caracters in a path
(translated from french so the wording is not exact but I guess you got the idea).
It's impossible to go and count individually each filename, and I see no option to either skip them or rename them.
Cheers.
PS : I hesitated between bug or suggestion, I finally decided for bug as I can't revover the files.
If you are recovering to a separate device then make the name of the receiving folder as short as possible, for instance d:\r
