I have a flash card that suddenly said it needs to be formatted. Currently it shows up formatted as RAW which I'm unfamiliar with.
Is this program compatible with this formatting?
Would this program find the files if I did a quick format and then ran it or would that cause me to lose the data?
Lastly, this program is not compatible, any recommendations?
Thanks a lot, whoever reads this.
