EMMA
1
First off, I love your program as its the best around!!
Thanks so much for keeping it FREE!!! Appreciated.
Now, my question is if I have a program or programs on my PC that I rarely/occasionally use I am told that CCleaner will remove them. Is this true?
Thanks for your time.
EMMA
No, it won't remove any programs (unless you use the Tools>Uninstall section which I'd suggest you leave alone till your familiar with it).
Have a look through the CCleaner beginners guide and come back if you have any unanswered questions:
http://www.internetrotsyourbrain.com/ccleanerbeginnersguide/
EMMA
3
Appreciate your time and the link.
