How do I fix my sound problem and prevent it from happening again? Which box to I uncheck??
Have you checked your levels first? Did you use the registry?
Sorry, don't know what you mean.....levels? And yes I ran ccleaner thru the registry.
I think ident means your sound levels in volume control.
OH.......Yes I checked the sound level on my computer and on my external speakers. I pluged my external speakers into an iPod and the work fine so it is not a fuse in the speakers. I checked control panel under Hardware/Sound....then Sound.... I seemed to me ok??
Don't know what else to check?
If you used the registry bit of ccleaner (issues) did you make a backup when it asked if you wanted to?
Sorry!......not sure but think so.
It's working now???? don't know why? I changed some of the cookies in options and closed ccleaner and now it works? go figure? Thanks!
If you did it is saved by default in 'my documents''
You right-click on it and select merge.
It looks like a piece of paper with blue blocks on it
