Ram Problem
Hi, recently my friend got into a ram problem. He currently run on 756mb of ram (one 512 and another one is a 256). His mobo has 3 slot when he insert another 256mb to it. The 1GB ram seem to be slower than 756mb worth of ram. Anyone can advise him what is the problem going on? Thanks.
Have you determined how much RAM his machine can handle? You may using too much.
This site can help determine what is the max for the machine. :)
good luck
That`s a good link for me as well. Planning on a memory upgrade.
It`s nice that you can download the scanner to run locally if you visit the site with anything other than IE.
Otherwise it`s another activeX install.
Thanks
