Question's about Screenshot's on Mainpage
Hello,
Im curious.On the Mainpage(CCleaner.com) there is a "Screenshot" section with various Pictures showing off what CCleaner can do.
Here are my Questions:
1.Who made those Screenshots?
2.In those pictures it looks like that the person who did the screenshot uses a skin for windows, or is it the default Skin from 64-bit/32-bit Windows 2003?
3.If it's not a default Skin made by Microsoft for Windows, where can i get or could see a Screenshot to see how it looks like?
Thanks.
MrG took them.
http://www.ccleaner.com/help/faq_general.asp#q1.4
MrG took them.
22658[/snapback]
out of these two(Classic2 v. 1 FINAL/Opus OS 1.5) id say that the Opus OS 1.5 is the closest one that looks like the skin usedon the screenshots i saw.
but unfortunatly it seems it is not the same.
could this possible because of 64-bit OS on the screenshot section and 32 OS on the deviantART link?
thanks for the help so far.
E: on the first link ---> http://www.deviantart.com/view/4245120/
there is a small app in the systray that looks like some app from nVidia, id like to know what kind of app it is, thanks again...
bump:/
It's Classic2 v.1 Final
The nVidia app in the bottom is just the nVidia Task Manager.
22751[/snapback]
firstly:thanks for the reply. what i dont uunderstand is that classic2 v.1 Final skin doesnt look same as the skin used on @ the screenshot section :S
oh and btw ive never heard about that nVidia Task Manager before, i thought its an utility made by entech taiwan but its something else i guess?
whats it?
sorry for ninja bumping this but i really like to know whats nVidia Task Manager afterall, since i could not find anything on google about it, just some sites where people mentioned it but not what it is or where i could get it from.
Quite simply, nVidia task manager is the same as you can get from the control panel. You obviously have to have a nVidia graphics card first. There is settings not to show the task manager icon of you wish.
Quite frankly, as to why u so concerned about someone else's taskbar icon is beyond me, as it has no relevance to your original post. :huh:
