Hi, If I download a file to my Downloads folder and then move that file to the Videos folder and then later securely delete that file from the Videos folder will there be any remnants of that file in the original Downloads folder? I am also aware that you can set up CCleaner to securely delete from the Recycle Bin so I suppose this question could also be applied to files that you delete normally and then securely delete from the Recycle Bin. If I was to use a one-wipe secure "Delete from Recycle Bin" option, can traces of the file be left when you normally delete the file from its original folder?
