Hello all,
first, I'd like to tell you that your program is now one of my new best friend and thanks a lot for the good job you do on it !!
But, I have a question, I use Remote Desktop to connect on my home computer from my office computer (both are on Windows XP Pro SP2) and I use the mounting stuuf which permit to see my local disk on my Remote computer.
But it does not work anymore, and I just want to know what is clean by CCleaner ?
I 'm not sure that because I clean some stuff with CCleaner, but we never know ...
Thanks a lot for your answer.
