Question on CCleaner delete
Just installed CCleaner. Ran the program, a list of items came up to be deleted. Clicked on analyze and it has a list of items to be deleted. I do I delete this list?
Thanks
If you have left the default settings then this should be quite safe and beneficial (just click Run CCleaner).. Steer clear from registry clean until you are more confident.
So are the docs and items actually being removed? It just confused me a little as they said to be deleted.
What's in the list will be removed, but I think you will find that they are .lnk files or similar, which are shortcuts etc. No 'good' files will be removed, unless you keep them in temp internet files or other temp folders, which would be silly.
For further queries, Piriform Documentation
If you haven't really touched other settings, and it is the Default ones, I can say it is pretty safe! :)
The Registry is a different thing. Don't touch that :blink:
