question abou the /auto switch
Hi everyone,
When I use the /auto switch to run CCleaner from a batch file, does it clean up the registry as well?
Or do I need to run the registry cleaning in the normal console of CCleaner?
Thanks,
Kind regards,
DNE ;)
No the batch file does not clean the registry as well, that needs to be done with you in attendance so to speak.
Have a read here as this may help you understand the program a bit better.
http://www.internetrotsyourbrain.com/ccleanerbeginnersguide/
Welcome to the forum :)
Hi Hazelnut,
Thanks for the reply.
Exactly my thoughts. A bit tricky to clean a registry without your attention. :)
Thanks for the link. I?ll start reading.
Kind regards,
DNE. ;)
