To update a software package I may need to first remove the prefetch files that were used by the previous version.
I think rather than identifying and then removing all related prefetch files it would be much faster and easier to simply delete everything in prefetch.
It now takes about 30 seconds from leaving BIOS to get the login screen,
and another 30 seconds from login before it is ready for me to launch whatever I choose,
and if I am still getting coffee when it is ready for me, the HDD still has busy bursts for another 30 seconds as it remembers a few more things it needs to do.
When I launch Firefox that takes about 10 seconds.
I believe deleting prefetch does no harm other than being a little slower, and it will automatically rebuild prefetch and then get up to speed.
I would appreciate advice upon how much longer it would take to start up after a purge,
and how many reboots for it to rebuild prefetch and get back to speed,
and how many times would I need to launch Firefox before that also was up to speed.
Are there any other issues I should be aware of ?
Background to my interest :-
Some software can be auto updated "in-place".
Some requires un-install of the old before the new will load.
Some may fail to update for many reasons :-
1) the MSI installer trips and stumbles over old remnants that were not removed ;
2) Windows Security Centre blocks an A.V. / Firewall update until the repository is rebuilt ;
3) Other Windows gotcha's too numerous to mention.
Comodo security is this sort of software.
An upgrade will, with luck, only require the use of Windows Add/Remove to purge the old before installing the new,
but when luck runs out there is a script to purge traces of the old from the registry and files/folders.
I have now encountered a view that even the old prefetch files should be removed,
and it seems to me much easier and more reliable to purge all prefetch instead of individual identification and deletion.
Regards
Alan
