problems while retrieving files after scanning
I installed Recuva to recover files from a corrupted external disk.
I started the deep scan: recuva traced about 190,000 files
during the recovery phase (unfortunately I selected them all) the program froze.
Is there a system to recover the scan and start the recovery again or do I have to start all over again? consider that it took almost two days to scan....
Thank you!
Unfortunately not. You will have to start again.
thank you, I try again. Do you advise me to recover a few files at a time? Another question: will i not be able to recover the original names of the files and folders?
Yes, I would recover files in a bunch at a time, step by step is the way. The original file names will be preserved if they are shown in the scan. For files found with a deep scan, those with a file name of [001234].jpg for instance, file names can't be retrieved.
