Whenever I run CCleaner I am unable to get back into one programme I use even though I have the cookies for this site marked to be saved.
As a landscape photographer, I use a programme called The Photographers Ephemeris. This basically tells me where the sun will be at any time during the day. After I have run CCleaner on my PC all I get from this programme/App when I try to go back into it is a greyed out “I Agree” button. The “I Agree” button tells me I have problems with cookies for that particular site.
I have no problems at all with any other site that I use after running CCleaner.
Since I originally posted this thread, I spoke to the developers of The Photographers Ephemeris telling them the problem. They came back with the following: “You might want to check that CCleaner is not set to clear browser local storage for The Photographers Ephemeris. The web app primarily uses browser local storage rather than cookies, so it’s possible that’s getting cleared out.”
Not sure if that helps solve the problem at all.
