Problem
post-5699-1151189622.jpgUm... evertime I Run the program I think it uninstalls Macromedia Flash Player
cause everytime I run it and macromedia is checked, the next time I go to the net and it's needed it says that I have to install it again
it wasnt doing this for the older versions....I might be wrong but asking is what I think is best
Welcome Animeniac :)
Have you tried unchecking it Macromedia under the Applications Tab? If so, what happens?
What OS are you running?
