Hoy.
I have a problem.
I delete an entry (removing the program from Add/Remove Programs) and the program doesn't work properly.
How can I recover this entry?
Jan Martens
Hoy.
I have a problem.
Jan Martens
Welcome to Piriform Jan.
I think you've posted in the wrong forum. Thats a CCleaner question. Repost or let admin move it for you.
Do you mean that you've removed a program using Windows Control Panel Add/Remove? If so then you will have to reinstall the program, as it will be almost impossible to identify the deleted files and folders, and there are other associated changes, register entries, etc.
