I'm using the latest Speccy (v1.13). I didn't check with the previous version, but Total Physical in RAM sector displays only "MB", not the real size (1 GB actually). Here is the full RAM information.
Thanks,
RAM
Memory slots
Total memory slots 2
Used memory slots 1
Free memory slots 1
Memory
Type DDR2
Size 1024 MBytes
Channels # Single
DRAM Frequency 266.0 MHz
CAS# Latency (CL) 4 clocks
RAS# to CAS# Delay (tRCD) 4 clocks
RAS# Precharge (tRP) 4 clocks
Cycle Time (tRAS) 12 clocks
Bank Cycle Time (tRC) 16 clocks
Physical Memory
Memory Usage 46 %
Total Physical MB
Available Physical 542 MB
Total Virtual 2.40 GB
Available Virtual 1.92 GB
SPD
Number Of SPD Modules 1
Slot #1
Type DDR2
Size 1024 MBytes
Manufacturer Elpida
Max Bandwidth PC2-4300 (266 MHz)
Part Number EBE11UD8AGSA-5C-E
Serial Number 16FCB64B
Week/year 35 / 06
SPD Ext. EPP
JEDEC #3
Frequency 266.7 MHz
CAS# Latency 5.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 12
tRC 16
Voltage 1.800 V
JEDEC #2
Frequency 266.7 MHz
CAS# Latency 4.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 12
tRC 16
Voltage 1.800 V
JEDEC #1
Frequency 200.0 MHz
CAS# Latency 3.0
RAS# To CAS# 3
RAS# Precharge 3
tRAS 9
tRC 12
Voltage 1.800 V
Thanks for following up. The developers read, though rarely comment on, every thread. They may ask you for more information if they are unable to recreate the problem in their lab.
I would like to elaborate more on this. A few days back I upgraded my memory to 2 GB (added another 1 GB). Both memory slots are now occupied. Using the latest v1.15 Speccy correctly identifies the Total Physical. So, in one way the problem I had is fixed.
But it still persists on the Asus Eee PC 1105 (see above post).
