Hello I've got a big problem in here.
So first of all i have to say that CCleaner is a great program ![:D]()
But, to the point. So my problem is that since few days Cclener finds 1,5 gb of data to throw out.
At first I thought it's ok, but when I throw out them for the first time, then after rebooting Win scandisc started, and it regained all those files. I started analizing after starting WIN and it turned out that these files are back on my drive. I throw them out once again... And you know what happened... Scandisk...
What's wrong about this?
It would be helpful if you perhaps posted a screenshot of the files while in CCleaner window.
Are these files one you have had a long time?
Is this an issues clean or a "normal" clean?
XP or Vista?
XP or Vista?
XP.
I will list you this files. Copy all log from CCleaner, and maybe you will be able to work out sth.
"Are these files one you have had a long time?" I have no idea what are these files...
"Is this an issues clean or a "normal" clean?"
Don't how it's in english because of having polish language version, but i'll try to describe.
it''s the icon with wiper not the one with *.reg files icon. (so it is the upper one)
Here you have the log:
http://www.box.net/shared/smgl2ysbro
It looks like these are files from Colin Mcrae DIRT game, but what they have in common with AVAST 4??
It's my antivirus ![:o]()
