hi
the last version released today have a problem with registry section
after a scan if i click in "fix all the errors" nothing happens and it shows the same errors(all of them) if i scan again
but if i fix the errors one by one, it seems to work
hope the people here can understand me..sorry about the bad english
its cc 2.00.495
Hi,
I'd like to add my two penn'orth to vecchio's comment. I've just updated from v1.41.544 to 2.00.500.
Running XP Home SP2 and through years of running CC in its various versions have never had a problem till now.
It was reluctant to backup (worked on the third attempt) and refused to "fix all errors". It would however, do so individually.
Am I missing a trick somewhere, or is this a genuine glitch please? ![:wacko:]()
mocca
3
hi
its cc 2.00.495
I will make a guess (as you do not make explicit) - that you are running CCleaner on Vista?
The solution - right click on CCleaner icon and 'run as administrator'. Your issues will be removed permanently.
