Well I am back and followed the automatic fix it method as I found the following when I tried to fix it myself manually via "Run" and use the command...the following was found:
1.regsvr32 urimon.dll "LoadLibrary (urimon.dll)failed. The specified module could not be found.
2.regsvr32 mshtml.dll "was loaded, but the DllRegisterServer entry point was not found. This file cannot be registered.
3. regsvr32 shdocvw.dll "DllRegisterServer in shdocvw.dll succeeded
4. regsvr32 msjava.dll "LoadLibrary (msjava.dll)failed. The specified module could not be found.
So I knew that I had to do the MS Fix It 50191.....with the wizard and did a test after it completed and found that still no Links will open.
But having more time at the moment I looked more carefully at my mail that is being unco-operative and I have found a note at the top indicating"this message has been converted to plain text'?
I am definitely not sure what this is all about?
Anyone have any ideas and BTW I genuinely appreciate the interest and support.
Cheers.
Am very puzzled?
BTW, I also checked my Browser as was suggested in the second last post in this thread and found my "Set Program and Defaults" is 'custom' and when I tried to 'tick' off 'Internet Explorer' instead of 'use my web browser'....I went back and the 'tick' mark was back in 'use my web browser'.
Just thought that I would mention that as well.
Seems to me that this changing of my mail message to 'plain text'.....maybe the culprit???
Thank you again for your patience and interest as I sit here and scratch my non tech brain at 1 am. Will be up early and hope that there maybe suggestions. ciao for now!
I forgot to mention that my A/V is Kaspersky and I use Prevxx and have used them together for several years and had no bugs etc.
I am wondering if an update to xpsp2 could cause this change to plain text as now some of these emails are ending up in my 'junk mail'?
Computers are great but it is the operator ... me that creates the problem ![:blink:]()
...unfortunately !
