Hello,
i've found a problem with Defraggler, I hope you will fix it in the future.
I've created a partition of 30GB, for only World of Warcraft game, and it works correctly but I can't defrag files on it.
The calculate dimension is 29,2GB (from Windows), with 14,8GB free.
I see many red blocks on the preview window.
I'm using Windows 7 x64.
Thank you in advance.
metalj
2
At this moment, Defraggler only has preliminary support for Windows 7 (See here).
I would recommend you to do a "quick defrag" and then do the "full defrag". ![:)]()
See here).
I've tried all options/ways, Defraggler don't defrag it.
