Problem with graphics
So today i've opened Speecy to check my temperature , and it doesnt show the temperature of the graphic card , it says
A device attached to the system is not functioning.
Anyone knows whats the problem with it and how i can fix it?
http://prntscr.com/9qv5tl
also problems with mainboard?
Yes maybe it doesnt show temperature , and the graphic doesnt read it at all.
those Intel Conroe chips were released late 2007.
and the ASRock socket 775 motherboards firmware I suspect is too old (or at least not compatible) with either your Windows 7, WMI or Speccy.
you could try an older version of Speccy or maybe a BIOS update to the motherboard. (long shots though)
no proper identification of ram+mainboard+graphic...
have you installed another mainboard-driver?
what mainboard and graphic do you have?
have you see in the computer, if the cables are properly connected?
Yes they are properly connected , till 2-3months i could see the graphic and the motherboard , ive got Nvidia Geforce Gt 610 , and i've got some problems with the graphic card drivers can that be a problem or something?
