Hey new t this form but I have love the product. I am currently using the latest google chrome internet browser. Recently every time I use Ccleaner it erases everything minus the saved form information on google chrome. Is there a way to fix this? Thanks in advance and grettings from Mexico.
Welcome to the forums!
In applications there are google chrome boxes, untick them.
ah good point what needs fixing
1) you don't want anything deleted (if so follow Winapp2's advice above)
or
2) you like that everything is deleted but want saved form info deleted
Sorry should of been more specific. I would like for everything to be deleted including the saved form info. I click the box to dealt the saved form info but it doesn't dealt it. I hope I make my self clear.
ive noticed the same problem saved form cleaning not working on cc v236 1233 chrome 6.0.472.63 win7
chrome 8.0.522.5 ccc 2.36.1233 xp3 mse antivirus
ccc fails to clean chrome cache in recent versions- this was done before- can be cleaned via chrome options, but this is no longer a one step solution and only realised when trying to find recent downloaded files- have used ccleaner for years.
ccc fails to clean chrome cache in recent versions- sorry forgot to include the fact that a number of chrome.exe processes still run after chrome closed - this in itself prevents ccc from deleting chrome files- still looking for a one click solution.
you have to find out why your chrome is not correctly exiting, after this I believe chrome will clean properly. More often than not the not closing is due to a poorly constructed Addon or theme.
Chrome atill running after exiting fixed with new version - Chrome 9.0.587.0 dev - ( I assume this corrected the problem!)
CCC now deletes Chrome Cache on my machine
Thanks
Awesome, Thanks for following up
