Problem with Firefox Plugins
After closing and re-opening Firefox three times (3 times!) Bitdefender TrafficLight was still disabled.
Windows 10, CCleaner and Firefox all latest versions.
Windows 10 Home edition, 2004, Build 19041.508.
8 hours ago, Léon said:
		<span>After closing and re-opening Firefox three times (<strong>3 times!</strong>) Bitdefender TrafficLight was still disabled.  Windows 10, CCleaner and Firefox all latest versions. Windows 10 Home edition, 2004, Build 19041.508.</span>
Hi Léon:
I updated to CCleaner Free Portable v5.72 today and repeated the same steps described <above> and my results were the same (i.e., my Bitdefender TrafficLight icon re-appeared in my browser toolbar after a second re-start of my browser). However, I checked my Firefox add-on manager during today's test and noticed it reported extension was disabled, even though the TrafficLight icon re-appeared in my browser toolbar and was functioning normally.
From today's test after the update to CCleaner Free Portable v5.72:
1. Open Firefox. Confirm Bitdefender TrafficLight is working normally in Firefox v81.0 (i.e., add-on manager at Tools | Add-ons | Extensions shows extension is enabled and the icon appears in the browser toolbar). Close Firefox.
2. Open CCleaner. Disable Bitdefender TrafficLight for Firefox v3.1.3 extension from the CCleaner add-on manager at Tools | Browser Plugins | Firefox (i.e., select the TrafficLight extension and click the Disable button. Close CCleaner.
632757332_CCleanerv5_72BrowserPluginsDisableFFBitdefenderTrafficLight28Sep2020.png.11768a77b40266cde21ff47db359d3b3.png
3. Open Firefox. Go to the Firefox add-on manager (Tools | Add-ons | Extensions). As expected, the add-on manager shows TrafficLight is disabled and the extension icon (a green circle with white check mark on "safe" sites) has disappeared from the browser toolbar in the top-right corner of the browser.
1104017020_FFv81_0BitdefenderTrafficLightDisabledbyCCleanerv5_7228Sep2020.png.3f2dd7088a438b97dac40f56b29ab279.png
4. Close and re-open Firefox. Go to the Firefox add-on manager (Tools | Add-ons | Extensions). The add-on manager still shows TrafficLight is disabled but the TrafficLight icon (green circle with white checkmark) reappears in the browser toolbar. TrafficLight seems to behave normally [e.g., the TrafficLight status icon (green/yellow/red) appears in Google search results]. Open and close Firefox multiple times to confirm the TrafficLight icon loads into the browser toolbar at every browser launch. Close Firefox.
477223633_FFv81_0BitdefenderTrafficLightToobarIconReappears28Sep2020.png.37409c587451f26ca3b5e1a5988c7bbe.png
5. Open CCleaner. CCleaner add-on manager at Tools | Browser Plugins | Firefox still shows TrafficLight is disabled (Enabled = No, see image in Step # 2) even though the TrafficLight extension loads in the browser toolbar as shown in Step # 4 and behaves normally.
I fiddled around and eventually got the two add-on managers synced so that the enabled / disabled status of my TrafficLight extension is correct in both Firefox (Tools | Add-ons | Extensions) and CCleaner (Tools | Browser Plugins | Firefox) but it took a bit of work. At one point my TrafficLight extension was enabled in Firefox at Tools | Add-ons | Extensions and the icon in the browser toolbar was visible but CCleaner (Tools | Browser Plugins | Firefox) showed the extension was disabled (Enabled = No) and threw an "access denied" error (sorry, I can't recall the wording of the full error message) when I clicked the Enable button.
I use the portable version of CCleaner downloaded from https://www.ccleaner.com/ccleaner/builds (i.e., CCleaner is not an installed program on my computer and the ccleaner.ini file resides on a USB thumb drive) so perhaps that's why it took me a while to get both add-on managers in sync. I don't think the fact that I still use Win 10 Pro v1909 (not v2004) would be a factor.
Regardless, this still doesn't address CCleaner's wonky behaviour with "special" Firefox extensions like the one-click search engines where Firefox will automatically re-enable one-click search engines if they are disabled in CCleaner. I suspect Andavari's suggestion <here> that Firefox has a built-in protection mechanism to prevent outside sources (including malicious browser hijackers) from modifying the user's search engines is the most likely explanation.
64-bit Win 10 Pro v1909 build 18363.1016 * Firefox 81.0 * CCleaner Free Portable v5.72.7994
Hello Imacri,
Because my TrafficLight icon is always hidden from the toolbar (if a warning comes, it comes anyway), I only looked at the add-on manager.
If you insist I will do the test again with the icon in the toolbar.
		<span>Because <strong>my TrafficLight icon is always hidden from the toolbar</strong> (if a warning comes, it comes anyway), I only looked at the add-on manager.  If you insist I will do the test again with the icon in the toolbar.</span>
Hi Léon:
I'll leave it to you to decide if you want to do more testing. The latest test results I posted <above> were really for the benefit of any Avast / Piriform employee following this thread who agrees that they need to open a formal bug report. I only wanted to confirm that the behaviour I see on my computer was consistent for both CCleaner Portable v5.71.7971 (rel. 14-Sep-2020) and v5.72.7994 (rel. 23 Sep 2020) so they know this isn't a new bug that was introduced in v5.72.
At the end of the day, I never use the CCleaner add-on manager at Tools | Browser Plugins to manage my Firefox add-ons. I only posted in this thread to show I could reproduce the problem the OP GeorgeNelis reported in this thread where one-click search engines hidden / disabled in Firefox v81.0 have a status of Enabled = Yes in CCleaner.
According to the releases notes <here>, CCleaner v5.70.7909 (rel. 06 Aug 2020) "Fixed a bug where CCleaner could wipe extension settings in Firefox if using a Firefox account" but I know several Firefox users who don't use a Firefox Account and had their custom settings wiped in multiple Firefox browser extensions the first time they ran CCleaner v5.69 - see Krusty13's comments in the Norton Tech Outpost thread Firefox 79.0 to be Released July 28 for one example. After reading the 09-Jul-2020 Mozilla blog Changes to storage.sync in Firefox 79 I suspect that CCleaner v5.72 still has a few bugs related to Firefox's new storage.sync area for extension data that we're just discovering now.
Hello Imacri,
The only thing that really interests me in this case is:
I don’t like (to say it mildly) Bing, bol.com, DuckDuckGo, eBay, Google, Marktplaats and all their colleagues, so I don’t want them to be enabled in Firefox.
3 hours ago, Léon said:
		<span>Hello Imacri, </span>
		<span>The only thing that really interests me in this case is:</span>
		<span>I don’t like (to say it mildly) Bing, bol.com, DuckDuckGo, eBay, Google, Marktplaats and all their colleagues, so I don’t want them to be enabled in Firefox.</span>
This is exactly what we are saying; Firefox is enabling these search engines by default - and you can't stop it doing that.
If Firefox is closed then you can 'disable' them with CCleaner, but then Firefox just re-enables them again.
Nobody but Firefox/Mozilla can change that behaviour.
(I've searched online but have yet to find anyone who has managed to totally disable them permanently).
It's not something that CCleaner can change, Firefox would have to stop enabling/re-enabling them by default.
Yes, Mr. Nukecad,
It would be interesting to know where exactly in Firefox, CCleaner finds the information about these browser plug-ins.
		<span>The only thing that really interests me in this case is: I don’t like (to say it mildly) Bing, bol.com, DuckDuckGo, eBay, Google, Marktplaats and all their colleagues, so I don’t want them to be enabled in Firefox.</span>
Hi Léon:
I have no problem disabling (hiding) or removing my one-click search engines from the list of available search engines in Firefox 81.0 at Tools | Options | Search | One-Click Search Engines as instructed in the Firefox tutorial Firefox support article Add or Remove a Search Engine in Firefox - see my 24-Sep-2020 reply <here>. The image below shows I've disabled / hidden the Amazon and eBay search engines so they don't appear when I search from my Firefox address or search bar (note that the check mark next to these search engines has been toggled off), and if I wanted to remove a search engine like DuckDuckGo from that list I could highlight the search engine and click the "Remove" button. Nukecad is correct that "removing" those search engines isn't permanent since you can click the "Restore Default Search Engines" button to reset that list back to its default settings, but the search engines shouldn't spontaneously re-enable themselves as long as you configure your settings from within Firefox. As far as I can tell the one-click search engine settings are working in Firefox exactly as they were designed to do.
1990361447_FFv81_0SearchSettingsOneClickSearchEngines29Sep2020.png.fc771c143cc2ca9734c6b499e8ce0b31.png
_________________________________________________________
Problems only occur if you try and manage your Firefox one-click search engines from the CCleaner add-on manager at Tools | Browser Plugins | Firefox. As I showed in my 24-Sep-2020 images <here>, my Amazon and eBay search engines are correctly disabled (hidden) in my Firefox address and search bars but CCleaner always incorrectly reports these disabled search engines are enabled (Enabled = Yes).
And as others have reported in this thread, if you disable a Firefox one-click search engine like Wikipedia from the CCleaner add-on manager at Tools | Browser Plugins | Firefox (i.e., you highlight the Wikipedia search engine and click the Disable button to change the status to Enabled = No) the search engine is not actually disabled in Firefox...
168803981_CCleanerv5_72BrowserPluginsDisableWIkipedia28Sep2020.png.a803ef9b9fbabdd015c2269e67a26a18.png
248366260_FFv81_0SearchSettingsWikipediaSearchEngineNotDisabled29Sep2020.png.234c1120a250c28b44f8200b3c59dd28.png
... and the next time you open CCleaner the status will have reverted from disabled (Enabled = No) back to enabled (Enabled = Yes).
1869027441_CCleanerv5_72BrowserPluginsWIkipediaNotDisabled28Sep2020.png.774113e4251c67ec6e1f1b6c82efc16f.png
I don't think the issue is that the Firefox one-click search engines are spontaneously re-enabling themselves after being disabled in CCleaner. I simply can't see any evidence that they were ever disabled by CCleaner in the first place.
		...At one point my TrafficLight extension was enabled in Firefox at Tools | Add-ons | Extensions and the icon in the browser toolbar was visible but CCleaner (Tools | Browser Plugins | Firefox) showed the extension was disabled (Enabled = No) and threw an <strong>"access denied" error</strong> (<em>sorry, I can't recall the wording of the full error message</em>) <strong>when I clicked the Enable button</strong>....
Just an FYI for the Avast / Piriform employees that I managed to capture an image of the CCleaner error message today when I was testing with my Firefox one-click search engine settings in the CCleaner add-on manager at Tools | Browser Plugins.
186285960_CCleanerv5_72BrowserPluginsError28Sep2020.png.a62ac57d984a9022ab0bb309fd146212.png
At the time this happened, I had just clicked the Disable button to change the status of my Wikipedia one-click search engine in Firefox to Enabled = No as shown below (which didn't actually disable the search engine in Firefox as I demonstrated <here>), and when I highlighted the Wikipedia search engine again and clicked the Enable button just see if the status would change back to Enabled = Yes the CCleaner add-on manager threw the above error.
1429221343_CCleanerv5_72BrowserPluginsDisableWIkipedia28Sep2020.png.fa548375cfb14c9bc28dd680488ca728.png
		<span>Yes, Mr. Nukecad, </span>
		<span>It would be interesting to know where exactly in Firefox, CCleaner finds the information about these browser plug-ins.</span>
Apparently Firefox also used to regard these search engines as extensions/plug-ins and they could be removed from the Add-ons manager.
You can't do that for the search engines anymore, and just when Firefox stopped letting you do that I don't know.
PS. The talk about BitDefender here is confusing things; BitDefender is not a search engine and not a defualt in Forefox.
The best option would certainly be:
If we don’t want these search engines, allow us to remove them for good. Because we can‘t do this, this discussion was born.
Imacri could well be right: they can’t be completely disabled at all, not even temporarily.
We need to find a way to live with them.
		W<span>e need to find</span> a way to live with them<span>.</span>
Easy, just untick them in Firefox Settings/Options and the Firefox searchbox will only use google.
Or:
Don't use the Firefox searchbox at all and set your Firefox homepage to google or whatever search you do want to use. (PS. 'New Tab Homepage' is a useful Firefox add-on if you do that).
And (at least for now) don't bother disabling them with CCleaner, because Firefox will simply re-enable them again.
I guess that mozilla are somehow making money by having them enabled by default?
When I saw the search engines for the first time, my wish was to never see them again. Not even in CCleaner.
The same as those annoying Windows 10 components like Edge or Defender.
Why can‘t we choose to get rid of them for ever?
You'd probably have to use some clone of Firefox that another team develops to get what you want (as an example I use SRWare Iron instead of Google Chrome). Search engines are probably big money for web browsers.
Right: next to Firefox SRWare Iron is the browser for me too.
For a long time I was on Waterfox, but it went down the hill.
		Apparently Firefox also used to regard these search engines as extensions/plug-ins and they could be removed from the Add-ons manager.  You can't do that for the search engines anymore, and just when Firefox stopped letting you do that I don't know.... just <strong>untick them in Firefox Settings/Options</strong> and the Firefox searchbox will only use google.
Hi nukecad:
I've been using Firefox as my default browser since Firefox 3.6 was released in Jan 2011 and don't recall seeing the one-click search engines display in the add-on manager as an extension or plug-in at Tools | Add-ons, but I might be wrong about that. Are you sure you aren't thinking of browser toolbars like DuckDuckGo Privacy Essentials, Amazon Assistant, etc. that are more like the "traditional" browser add-ons that can be downloaded and installed from the Mozilla AMO store at https://addons.mozilla.org/en-CA/firefox/? These toolbars sometimes come bundled inside free software installers as PUPs (potentially unwanted programs) and will appear in the add-on manager as an extension.
		<span>...If we don’t want these search engines, allow us to remove them for good. Because we can‘t do this, this discussion was born.  Imacri could well be right: they can’t be completely disabled at all, not even temporarily.</span>...
Hi Léon:
Instead of unchecking your one-click search engines at Tools | Options | Search | One-Click Search Engines to disable (hide) them, have you tried my suggestion <here> to use the Remove button to remove them? For example, if I want to remove the Bing search engine from my list of available search engines, I can highlight Bing and click Remove...
1792181971_FFv81_0SearchSettingsBeforeBingRemoval30Sep2020.png.cddb8ad1aacd9018a1aa2c080f032355.png
... and Bing disappears from the list of available search engines as well as the address and search bars. As I noted before, if you accidentally delete the wrong "default" search engine or you decide that you'd like to restore it you can add it back to the list by clicking the "Restore Default Search Engines" button, but if you delete a custom search engine (e.g., youtube.com) that isn't on your list of "default" search engines that custom search engine cannot be restored quickly using this "Restore Default Search Engines" shortcut and you will have to add it back manually again.
1336809112_FFv81_0SearchSettingsAfterBingRemoval30Sep2020.png.2a9630c58a17107019cf367d3d6ecc0a.png
The point remains that these default search engines are not doing anything at all unless they are ticked and you use the Firefox searchbox.
They are not loading, taking up memory, or doing anything else, unless/until you call them from the Firefox searchbox.
If you don't want to see them then hide (remove) them from the One-Click search engines and forget them.
(Or take the Firefox searchbox off your toolbar altogether).
Hello Imacri,
Removing the search engines in Firefox itself was the very first thing I did (Google included, of course: use Startpage or Qwant).
Finding them back in CCleaner later was a rather unpleasant surprise.
That made it so difficult to forget about them, Mr. Nukecad.
That’s why we are still talking about them today.
		...I am having an issue with the combination CCleaner (CC) and Firefox (FF), both on the latest release (V5.72, 81.0)
		Within FF i have deleted several search engines like Bing and DuckDuckGo and within CC i have disabled their extensions using 'Tools','Bowser plugins'.
		After restarting FF and starting CC, the search engines don't show in FF but do show re-enabled in CC....
Could one of the Avast / Piriform employees please provide a status update and let us know if they've been able to reproduce the issue where enabling/disabling/removal of Firefox plugins from within CCleaner at Tools | Browser Plugins | Firefox does not correctly reflect the actual status of browser plugins in Firefox v81.x? My testing indicates the issues occurs with the built-in one-click search engines (Tools | Options | Search | One-Click Search Engines) as well as browser extensions downloaded from the Mozilla AMO at https://addons.mozilla.org/en-US/firefox/ (Tools | Add-ons | Extensions) .
Avast / Piriform ignored early warnings from users that CCleaner v5.68 was wiping custom settings in Firefox extensions in Firefox v79 and higher after Mozilla made changes to the storage.sync area for extension data storage - see cccirc's 01-Jul-2020 warning in Problem with Firefox 79 [fixed in v5.70] as well as the 09-Jul-2020 Mozilla blog Changes to Storage.sync in Firefox 79, which were both posted well before the buggy CCleaner v5.69 was released on 21-Jul-2020 and almost a full month before the stable release of Firefox 79 was officially released on 28-Jul-2020. Right now my confidence in CCleaner's ability to safely manage my Firefox browser (as well as Avast / Piriform's entire quality assurance testing program) is at an all-time low, so I would appreciate if Avast / Piriform could tell us if they are investigating whether this new issue with enabling/disabling/removal of Firefox plugins is caused by another bug in CCleaner.
64-bit Win 10 Pro v1909 build 18363.1082 * Firefox 81.0.2 * Windows Defender 4.18.2009.7 * Cleaner Free Portable 5.72.7994
Dell Inspiron 15 5584, Intel i5-8265U@1.60/1.80 GHz, 8 GB RAM, 256 GB NVMe SSD, Intel UHD Graphics 620</span>
