Hello, you excuse my English, I use a translator to be able to communicate with you. My problem since one of the last update of Ccleaner is that during the analize, I have a message concerning Edge and saying that the update of Edge not being finished, proposes either to ignore or to restart the pc to complete this update. When resuming analog after reboot, the problem is still present. Do you have a way to fix this problem. Thank you in advance, good to you, Christi1
Attached photo of the message.
![Edge.jpg]()
Quote
<span lang="en" xml:lang="en"><span title="">When resuming analog after <u>reboot</u></span></span>
When you see this message are you <em>Restarting</em> your computer, or are you shutting down and rebooting?
The two processes work differently on Windows 10 and a Restart is what is needed.
Each time I restart, the same problem reappears.
That sounds like the old Edge preloading issue, (which that warning message is supposed to fix, if you click the restart now button).
Try the instructions for the 'Automatic fix' here: https://community.ccleaner.com/topic/56335-solution-ccleaner-cannot-fully-clean-microsoft-edge-due-to-pre-loading/?tab=comments#comment-313491
