After a scan some files are listed in green as "state excellent"
Then I select them and use the right click to "secure overwrite" them (7 or even 35 passes), it performs the task with confirmation
After that, I do another scan and some of these files appear as they were before the delete
I see no differences between them et those for which the delete fonction has performed perfectly
I never noticed that with the precedent versions
