Hello there,
For a moment, I can not use CCleaner for this party can not charge and I do not know why! (Google Translate)
best regards
Norman FELTZ
Hello there,
best regards
Norman FELTZ
Uninstall CCleaner.
Reboot.
Install SLIM BUILD from here
https://www.piriform.com/ccleaner/builds
Does it work now ?
Problem with uninstallingUninstall CCleaner.
Reboot.
Does it work now ?
EDIT: Completed, this is very long.
Is CCleaner working for you now?
Its still not workingIs CCleaner working for you now?
What security software do you use?
If you boot your PC into Safe Mode does CCleaner work then?
How long have you waited for CCleaner to load? It sometimes takes a while if on USB driver or if using Winapp2.ini file.
