Hi,
If I have a toolbar plugin for Word2003, this entry in 'winapp.ini' reset the position of that toolbar.
[Office 2003]...RegKey2=HKCU\Software\Microsoft\Office\11.0\Common\Open Find\Microsoft Office Word\Settings\Save As\File Name MRU...
Can you remove or fix this?
Thanks
You could uncheck the cleaning of Office 2003 for more than just the issue you've discovered, such as having your settings remain intact which is the reason I no longer allow CCleaner to clean Office 2003.
I just disable that entry...
