Problem Starting Up!
Invalid BOOT.INI file
Booting from C:\windows\
HELP!
1. Configure the computer to start from the CD-ROM or DVD-ROM drive. For information about how to do this, see your computer documentation, or contact your computer manufacturer.
2. Insert the Windows XP CD-ROM into your CD-ROM or DVD-ROM drive, and then restart your computer.
3. When you receive the "Press any key to boot from CD" message, press a key to start your computer from the Windows XP CD-ROM.
4. When you receive the "Welcome to Setup" message, press R to start the Recovery Console.
5. If you have a dual-boot or multiple-boot computer, select the installation that you have to use from the Recovery Console.
6. When you are prompted, type the administrator password, and then press ENTER.
7. At the command prompt, type bootcfg /list, and then press ENTER. The entries in your current Boot.ini file appear on the screen.
8. At the command prompt, type bootcfg /rebuild, and then press ENTER. This command scans the hard disks of the computer for Windows XP, Microsoft Windows 2000, or Microsoft Windows NT installations, and then displays the results. Follow the instructions that appear on the screen to add the Windows installations to the Boot.ini file. For example, follow these steps to add a Windows XP installation to the Boot.ini file:
a. When you receive a message that is similar to the following message, press Y:
Total Identified Windows Installs: 1
[1] C:\Windows
Add installation to boot list? (Yes/No/All)
b. You receive a message that is similar to the following message:
Enter Load Identifier
This is the name of the operating system. When you receive this message, type the name of your operating system, and then press ENTER. This is either Microsoft Windows XP Professional or Microsoft Windows XP Home Edition.
c. You receive a message that is similar to the following:
Enter OS Load options
When you receive this message, type /fastdetect, and then press ENTER.
Note The instructions that appear on your screen may be different, depending on the configuration of your computer.
9. Type exit, and then press ENTER to quit Recovery Console. Your computer restarts, and the updated boot list appears when you receive the "Please select the operating system to start" message.
Thanx you
Just got to look for the discs now :P
Is there a way around it if i cant find the discs?
Thanx you
I read about this site somewhere but I don't have any idea if it's safe to use. I'm hoping someone sees this post and can advise you if it's OK.
It's called Bootdisk.com and if you can't find your disks maybe it's worth a try. You need to donate $4.00 via PayPal to access the files and programs being offered.
I'm sure it would be best if you can find your original disks or get OEM replacements and/or more advice from someone more experienced than me.
That being said, best of luck, hope you get things figured out OK...
Thanx you Mike :)
Thanx you Mike :)
Just Made Advanced Member :)
Awesome, only 450 more posts untill your a power member. B)
Heck, I bet we could post all 450 in one day :o
This page might be useful alot of downloads for different boot disk.
http://www.answersthatwork.com/
