Hi all,
I'm back... with good news: I was finally able to solve my pen drive problem using the link below
please read my posting below:
Re: cloned a 80G HDD to a 128G USB Flash stick
Nov 29, 2014
this link helped me:
http://www.techspot.com/community/to…4/#post-875300
Andy
----- Original Message -----
Sent: Friday, November 28, 2014 6:16 PM
Subject: cloned a 80G HDD to a 128G USB Flash stick
hi all,
happy holidays, etc.
this is an old issue, yet i am still working on it
in July 2013; I cloned my 80G HDD onto a 128G USB Flash stick
in Sept. 2013; I had a data loss…
so, I thought to recover my data using this 128G clone…
I put this 128G Flash stick into my computer, and it showed up as a Local drive, yet was inaccessible and with its LED flashing incessantly…
{this was after, I treated this 128G USB flash stick as if it were a whole computer, and I then attempted to use/misused Win Vista’s EasyTransfer program in a failed attempt to restore my lost data }
I later ran CHKDSK /f /r on it, and Chkdsk repaired and/or deleted about 7 “attributes” files
after which, this 128G Flash, only shows up as a Removable Storage(not Local) drive… and remains locked/data inaccessible yet without the flashing LED
the USB drive, when I clicked on it in My Computer, would give the/an error message “Insert drive into H: drive”… Insert? a drive? into my tiny USB drive? which isn’t even a CD or DVD drive? … I tried all the free home remedy data recovery tools that I could find… then I snail-mailed this thumb drive to my computer whiz baby brother… finally, I purchased {for $99.}, and downloaded Seagate’s data recovery tool, and had my brother return the drive… this was when I found the link above and it’s freeware DriveCleanUp program, and this solved my issue
what I think was/still is “the problem”/locked drive issue… is that the clone looks for the same C:\ assignation as my HDD{which, btw, I had been able to upgrade to 320G}
the problem now, I guess, is where can I find an old XP or Vista computer, to fool around with changing the C:\ drive letter?? [as I’m afraid to experiment on this my only one of my two working <Vista> machines]
this wasn’t the problem… my issue was caused by left-over USB Flash storage and other USB drivers which once installed were never removed
the freeware DriveCleanUp program, linked in the link, and properly installed{please study the instructions in the link} should help you with this issue… it helped me…
any thoughts appreciated,
Andy
(I did use my 7 System Recovery CDs in Jan. 2014 to reset my machine to its factory default settings... my computer was then "like new" yet I lost even more of my old data)
will advise further regarding further restoration attempts of my old data
