Hi friends, I use Defraggler very often on many computers, i have seen a problem on last version: after that I have run software and reboot, icons on desktop are been delete. I have tried it always on windows xp and never on vista.
Cari amici, uso defraggler quotidianamente su molti computer, ma ho riscontrato un problema nell ultima versione: dopo la deframmentazione la maggior parte delle icone sul desktop vengono cancellate. Questo non succedeva nella versione piu vecchia. Ho usato defraggler sempre su computer con windows xp quindi non saprei dire se il problema persiste anche su vista.
This don't happens on old version.
Greats
Luciano
Lucio
Hi Lucio,
It happens the same to me in my XP machine and I'm pretty sure the culprit is Defraggler v1.17.172. For a couple of days I've tried what I've read on internet but no luck so far. Also when right-clicking on the empty desktop the context menu doesn't appear.
This is indeed very strange but I'm not entirely sure if is possible to point the finger directly at Defraggler.
If icons had been deleted from the desktop this would have happened instantaneous and not after a reboot of Windows.
Richard S.
Honestly I can't say the icons dissappeared when Deffragler was running. I check the option to shutt the computer off when the defrag process finished overnight, so I just noticed the missing icons next morning when switched my PC on.
If you want to know more symtoms:
- icons gonne from desktop but actually still accessible in the folder C:\Documents and Settings\USERNAME\Desktop
- right click on the desktop doesn't work (no pop-up menu)
- Task bar working fine (I mention this because there seems to be a Windows bug that causes the Desktop icons and task bar to dissappear)
- XP with all Service Packs and updates installed
- antivirus software running and updated
- I tried expanding the EXPLORER.EX_ file included in the Windows XP CD and copying it to C:\WINDOWS folder but the problem is not solved
