problem of temperature display
Hello,
Since version 1.14 v the temperature of my graphics card ASUS EAH5750 Series is no longer displayed .
I have not changed the configuration or graphics card.
With version 1.13 v the temperature displayed as shown in the screenshot below .
http://imgur.com/SrEVu
http://i.imgur.com/DhCuu.jpg
Avec les versions 1.14 et 1.15 voici ci-dessous ce que l'on obtient : la température de la carte graphique ne s'affiche pas.
http://imgur.com/eWW6d
http://imgur.com/espVd
I hope this problem will be solved with the next update. In advance thank you. Goodbye.
attachment: display version 1.13
