Hi i’m new here.
and here my problem http://support.freeforums.org/viewtopic.php?p=516369#p516369
1) Open CCleaner
2) Click Applications
3) Checkmark Saved Form Information
If this fixes it, great!
_
If it doesn't:
1) Open Firefox
2) Ctrl + Shift + Del
3) Select Form & Search History, then set Time Range to Everything & press clear now
Do either of these methods clear the files you were looking to remove?
I've already do a checkmark at these options, but as I said already, but it’s looks like a bug
And nothing is working for me!
Could you post the original problem/info here, not just a link to another forum.
Which versions of CCleaner, Firefox & OS are you using? Are you sure you have closed Firefox properly before cleaning?
I use the latest version of Firefox & CCleaner and I have a Windows XP Pro and yes certainly I have to close the Firefox browser and all open windows, trying to find where this problem came from?!
