Problem CC cant delete
Hello Guys
I have a little Problem :
CC Cleaner cant clean 1 file he always stops there... (22%)
When i searched the file it was not there, so deleted the whole folder but still it did not help...
I you have any suggestions please help me
Thanks ;)
PS i am from Germany so u can also write in german ^^
What is your operating system? Vista? XP ?
They look like dump files created by error logs perhaps.
Are you able to look in the event viewer and see if there are any problems showing?
I have 32 bit Windows 7
What do you mean with event viewer ? has Ccleaner sth like that ?
sry i am not so pro with computers ^^
if you mean that ccleaner is crashing, he is not .. he just tries to delete a file the whole time doesn't matter if i leave him 1min 5min or 1h also doesnt matter if i close all other programms or not...
The file you are trying to clean looks like a crash dump file from another program (not ccleaner)
Have you had a problem with another program that is not working very well?
Do you use an antivirus program and all your scans are clean?
Hmmmm
Hmmm well my pc has some {Please Watch your Language} things many programms arent working correctly ^^
I use Antivir ... and Spybot search and destroy ...
It is time to let someone check your pc for virus and malware, please do not wait any longer.
There is a list of places here that do it.
http://forum.pirifor...=0
Let us know how you do.
Wuhuuu
Thanks for tryin to help me...
Today it just worked i don't know why or how...
but he could clean it completely
(It seems that i dont have any malware .... used 5 programms today to check my pc but noone found anything)
Again thanks alot hazelnut ;)
Glad to hear you are okay Orange Tree :)
If you have an malware problems any time, there is a very good German malware removal forum here
http://support.emsisoft.com/forum/11-hilfe-mein-pc-ist-infiziert/
