Which Operating System? Try running Windows Update to check if there is some Visual C++ updates or download latest redistributables (from www.microsoft.com).
You might have Firefox process(es) running at the background.
Windows 8 64 bit
i have the last Visual C++
No.
Did you check? Some of the processes might be named as firefox.exe and plugin_container.exe.
Are you using other browsers?
Can you post the full application error log from the Windows Event Viewer?
I'm sure, I checked several times
Where is the error log?
Press the Windows key (the one with the flag on it) +W
Type event into search box
This should then enable you to select 'view event logs'
They may take a few seconds to load.
Try selecting Windows logs and Application logs.
Double click on any that seem relevant (same time as your ccleaner error) and copy and paste error into a post here.
when does this error occur? At launch? At analysis? At clean?
Please run ccleaner in debug mode http://forum.piriform.com/index.php?showtopic=37347
and attach the log to this thread
