can somebody help me? after uninstalling vistamizer my laptop has some bugs...in the icons..there distances to each other are kinda anoying..
and also in my YU i think my icons had problem..
If the icon spacing still isn't what you want just input another setting following the above instructions until you have it perfect for your needs.
You may need to have the IconCache rebuilt. An easy way to do it is with the free Microsoft Tweak UI. Then in Tweak UI click Repair->Rebuild Icons, and hit the Repair Now button.
than you very much....it works
my setting..
icon=32
vertical/horizontal spacing=43
