Problem after cc cleaning
I used cccleaner7 and must have done too much because now my computer is so messed up, start btton doesn’t work, printer won’t print crosswords anymore…HELP!
Which parts of CCleaner did you use?
If you used the Registry Cleaner without being sure what you were doing then you could have corrupted the registry.
If you used the Duplicate Finder on default settings and removed everything that it found the you have probably deleted important System File duplicates and corrupted your system.
As they currently stand in CCleaner 7 both of those tools can be perilous for a non-techie user.
If you have a recent full system image backup now is the time to use it.
However I suspect that you won’t have a full system backup image and so I suggest that you repair your System by running DISM and SFC, see this for instructions how to do that:
https://support.microsoft.com/en-us/windows/experience/backup-recovery/use-the-system-file-checker-tool-to-repair-missing-or-corrupted-system-files
