private connection
If I use a private connection I cannot log in to Colnect and I will not receive any emails on Thinderbird from time to time. On KAMO when I set out a private connection, everything works again! What can I do to solve this
That may be intentional on the part of these services; they may be designed to block connections via VPN or similar software. This is especially common with email services (in an attempt to cut down on the ability to send spam), though more often in regards to sending email than receiving it.
Unfortunately, at this time, the only advice we can offer is to disconnect from Private Connection when using a service that conflicts with it.
Please feel free to get in touch with our support team via the Contact Us form located here: https://support.piriform.com/hc/en-us/requests/new?ticket_form_id=86507 or by emailing support@ccleaner.com directly so that we can retrieve logs that could help us improve the feature's compatibility.
Wenn ich, bei eingeschalteter Private Verbindung, mich auf diese Seite einloggen will - kommt die Meldung - Email oder Passwort ungültig.
Wenn ich die Private Verbindung abschalte, funktioniert das Login. Danke für ihre Mühen.
Quote
		If I want to log in to this page with the private connection switched on, I get the message - Email or password invalid.
		 If I switch off the private connection, the login works.  Thank you for your efforts.
Translated by Google
I have activated the private connection, but since then I can't access my account!
If I deactivate the private connection again, I can access my account.
Is this due to the camo or the Gameforge website?
