Printing 4 Duplicates per page
Hello! Long time listener, first time caller. I am attempting to print out flyers. I have attempted with microsoft word and adobe reader to print 4 per page. I select 4 per page and it will only print 1 on each page (quarter sized image) so I'm missing the other 3 on the page! Any thoughts? Thanks much in advance.
Perhaps look on Microsoft's Office website for a free template that you can use in Word.
You have to create 4 A4 pages first then use the 4 per page print command
Agreed. I've done that many times. The source file MUST CONTAIN 4 identical pages in this case. Then the printer lays them out in a 4-per-page layout.
-> Open the directory with the files you want to print on the same page.
-> Holding CTRL, select all the items you want to print with your mouse.
-> Right-click the group you selected, & choose Print.
-> Select the page layout you want to use.
I believe this will work for you. I am not sure if your using XP/Vista/7, but I believe it should work. Although options may differ slightly across OS versions.
* Edit: The others may know what they are talking about, & I may be blabbing for no reason, but I thought it would be something to try. Works for pictures!
I agree with the others (except SF who's correct that his is only for pictures, sorry) Copy the whole page. make a page break and paste (doing this until there are four pages)
Another method would be to seperate the page into quarters using a table(with the cells set to autofit and pasting the content into each cell. IMHO, this will look better in the end; however it will take (much) more work to get it to look right.
In addition to Nergal's suggestion, there are other things you can try if you get stuck.
Such as full screening the flyer, then selecting it & press Alt + PRT SCR key.
Open paint, CTRL + V to paste, then crop & CTRL + S to save.
Repeat for the others, & print as pics.
There should be many ways to pull this off, & hopefully you will find something you can use from one or more suggestions people have given here.
