Print Specs...
Is it possible to create a print to file or just 'print' option so users can have a hard copy of their configurations?
go to options>Advanced put a check in save settings to ini file
go to the ccleaner directory (e.g. c:\program files\ccleaner ) open ccleaner.ini with note pad and print :)
