Prevx CSI
Don't know how good this is but may be worth running for a second or third opinion?
Gave it a run on this Vista install and seemed quite fast without any probs.Nothing untoward found.
* Totally Free
* Rapidly scans for all forms of malware to let you know if you're infected
* No Install required. Runs completely independently and as many times as you like!
* Always up-to-date. The scanner checks with the up-to-the-second Prevx community database for the very latest threats.
* Run it now to see if your current protection has missed anything.
Prevx CSI
Thanks, Humpty. :) Ran it, took about 3, 4 minutes. Clean. Part of the report said no security products recognized. Do you know what that means?
edit: ran Kaspersky online scan later, just to check, but took longer. Clean also.
No sorry login123, can't really help as I have only ran this app once and don't know much about it.
I tried it not all that long ago and it couldn't make up its mind if something was malware or not, and it gave the stupidest damn report which was laughable and of no help whatsoever.
